Японские автомобили
17 сентября 2006
Acura MDX 2007
POWERTRAIN
Engine Type 3.7 L 24-valve aluminum-alloy SOHC VTEC(R) V6
Displacement 3664 cc
Horsepower, SAE net 300hp at 6000 rpm
Torque, SAE net 275 lbs-ft at 5000 rpm
Valvetrain 24-valve Variable Valve Timing and Lift Electronic Control (VTEC(R))
Compression Ratio 11.0:1
Redline 6500 rpm
Induction System PGM-FI multi-point injection
Ignition System Electronic direct ignition system
Throttle Drive-By-Wire Throttle System(TM)
Emission Certification CARB LEV II ULEV and EPA Tier-2, Bin-5
Bore and Stroke 3.4 x 3.8 inches (90 x 96 mm)
Engine Block Die-cast lightweight aluminum alloy
Alternator 12V-130 Amperes
Battery 12V-65AH
Required Fuel Premium Unleaded
Layout Transversely mounted, front-engine
Drivetrain Super Handling All-Wheel Drive(TM) (SH-AWD(TM))
Transmission 5-speed automatic with Sequential SportShift and Grade Logic Control
Ratios (:1) 1st
2nd
3rd
4th
5th
Reverse
Final 2.697
1.606
1.071
0.766
0.538
1.889
4.533
CHASSIS
Body Type Unit body
Front Suspension Independent MacPherson strut
Rear Suspension Independent Multi-link with trailing arm
Shock Absorbers Twin tubes - MDX Magneto-Rheological fluid monotubes - with Sport Package
Stabilizer Bars Front 23.0 mm diameter - MDX
24.0 mm diameter - with Sport Package
Rear 25.4 mm diameter - MDX
27.2 mm diameter - with Sport Package
Steering Type Torque-sensing, variable power-assist rack-and-pinion
Steering Ratio 17.0:1
Steering Wheel Turns (lock to lock) 3.29
Turning Circle (curb to curb) 37.6 ft
Braking System 4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist
Front Discs 13.0 inch (330 mm) diameter ventilated (w/ dual piston caliper)
Rear Discs 13.2 inch (334 mm) diameter drum in disc
Wheels 18 X 8 J cast alloy wheels
Tires P255/55R18 104H All-season
Stability Control Cooperative Vehicle Stability Assist(TM) (VSA(TM)) with Traction Control System (TCS)
CAPACITIES
Cooling System 2.4 gallons/9.2 liters
Fuel tank 21.0 gallons/79.5 liters
Volumes Passenger -142.2 cubic ft
Cargo w/ rear seats up-15 cubic ft
Cargo w/ 3rd row folded-42.9 cubic ft
Cargo w/ rear seats down-83.5 cubic ft
Engine Oil Change w/ Filter- 4.5 quarts/4.3 liters
Total - 5.3 quarts/5.0 liters
FUEL ECONOMY
EPA Fuel Mileage - City/Highway 17/22 mpg
EXTERIOR DIMENSIONS
Wheelbase 108.3 in (2750 mm)
Track, front 67.7 in (1720 mm)
Track, rear 67.5 in (1715 mm)
Overall Length 190.7 in (4844 mm)
Overall Width 78.5 in (1994.2 mm)
Overall Height 65.9 in (1679.3 mm)
Minimum Ground Clearance (1G) 7.33 in (184.7 mm)
Approach/Departure Angle Approach - 28.0 degrees
Departure - 22.9 degrees
Breakover - 20.2 degrees
WEIGHTS
Curb Weight 4539 lbs (2063 kg) MDX Sport - 4554 lbs (2070 kg)
with Technology Package - 4550 lbs (2068 kg)
with Technology & Entertainment Packages - 4578 lbs (2081 kg)
with Sport & Entertainment Packages - 4587 lbs (2085 kg)
Weight Distribution (% front / rear) 56/44
TOWING
Maximum Towing Capacity 5000 lbs
INTERIOR DIMENSIONS
Front Head Room 39.2 in (994.6 mm)
Leg Room 41.2 in (1047.7 mm)
Hip Room 59.0 in (1498.2 mm)
Shoulder Room 61.6 in (1565.4 mm)
2nd Row Head Room 38.6 in (980.3 mm)
Leg Room 38.7 in (983.4 mm)
Hip Room 59.1 in (1502.4 mm)
Shoulder Room 61.5 in (1561.0 mm)
3rd Row Head Room 35.7 in (906.4 mm)
Leg Room 29.1 in (740.1 mm)
Hip Room 42.0 in (1089.4 mm)
Shoulder Room 57.1 in (1449.9 mm)
WARRANTY
Vehicle 4-year/ 50,000-mile limited warranty
Powertrain 6-year / 70,000-mile limited warranty
Outer Body Rust-Through 5-year / unlimited-mile limited warranty
6 просмотров
изменен 17 сентября 2006 в 13:58
2007 Acura MDX 2006 BMW X5 3.0i 2007 Lexus RX 350 2006 Porsche Cayenne 2006 Volvo XC90 2.5T
Overall length, in. 190.7 183.7 186.2 188.2 188.9
Overall width, in. 78.5 73.7 72.6 75.9 74.7
Overall height, in. 68.2 67.5 66.1 66.9 70.2
Wheelbase, in. 108.3 111.0 106.9 112.4 112.6
Track, F/R, in. 67.7/67.5 62.0/62.0 62.0/61.2 65.2/65.8 64.3/63.9
был 21 час назад
НаFord Mondeoизменен 17 сентября 2006 в 14:05
Прошлая посимпотнее была, эта какая-то тупо брутальная (в плохом смыле брутальная)...
изменен 17 сентября 2006 в 14:09
Как это было....
изменен 17 сентября 2006 в 20:37
А мне кожется в полне неплохо, современный дизайн. 8)
изменен 17 сентября 2006 в 20:47
симпотно, но вот задние фанари я где-то видел такие, похожи на новые аудюшные )
изменен 17 сентября 2006 в 22:27
Мне понравилась....хоть и фонари Аудюшные..... teeth teeth
Чувствуется преемственность...это хорошо!
Тот кто выбрал в первый раз....почувствует только "евроремонт".... teeth teeth
Тот кто пока ездеет на старой моделе...тоже в строю т.к координально все не поменялось....
Узнаваемость на 100%!!!
изменен 18 сентября 2006 в 23:12
Отличный аппарат!...Ждём зимы...
изменен 7 января 2007 в 00:58
Уже стоит на Каширке в ТК Москва на 1м этаже....
Пожалуйте смотреть щупать и делиться впечатлениями... teeth
изменен 7 января 2007 в 14:31
ММммммМ, давно там не был... хоть и живу почти напротив teeth
надо бы зайти поглядеть tongue
изменен 7 января 2007 в 14:36
jets...отойди подальше чтоб взгляд захватил Ку7 и Акуру сзади, и посмотри на зад фонари teeth
изменен 7 января 2007 в 14:47
я даже знаю какой будет результат...
изменен 7 января 2007 в 16:11
Ты знаешь есть подсознательное сходство...но не более...
Все таки другие при рассмотрении....
Расстроил Прадо cry так пахабно хром наложить на решетку даже Кетайцы себе не позволяют... cry
изменен 15 января 2007 в 00:11
Уже продана... 8) 8)
С переди...
С зади...
изменен 15 января 2007 в 00:14
255/55/R18 8)
да, точно, спасибо что напомнил, блин деньги отдал, а забрать забыл как всегда...
изменен 15 января 2007 в 00:16
Тааак посмотри какого цвета собачка....? teeth teeth
http://forum.avtomarket.ru/viewtopic.php?t=14519&postdays=0&postorder=asc&start=450
